Shift Return Spring?
Old Oct 3, 2012 | 07:24 PM
johncool54's Avatar
Default Shift Return Spring?
95 F3. She will go into gear fine, but I have to lift my shifter manually with my foot every time to get it ready for the next gear.
has anyone had to replace the shift return spring?
Splitting cases is what its looking like
Old Dec 7, 2012 | 12:32 AM
bdjuju's Avatar
Registered Users
Any resolution with this? I seem to have the same issue with my '98 F3.
Considering how troublefree it's been for the last 83k mi, I really can't complain & the bike deserves a little attention.
Old Dec 7, 2012 | 02:18 PM
Conrice's Avatar
isn't what you're talking about right behind the clutch basket? you should not have to split the case for that....
not exactly sure, but if you were going to split the case, you'd need to take the clutch and basket out anyways.... unless the casing is radically different from other bikes, you should most likely be able to do it without having to split the case. are you talking about #10 or #8? 8 should definitely be on the outside, and i'm pretty sure you can still change 10 without splitting... on most bikes anyways
dyracuse
Feb 16, 2010 07:11 AM
SpecR
May 15, 2008 02:14 PM
BlindLOKI
Sep 13, 2006 11:29 PM
BlindLOKI
May 18, 2006 01:00 PM
