Choke spring (specifically the SE arm spring)
Old Feb 14, 2010 | 07:48 PM
dyracuse's Avatar
Default Choke spring (specifically the SE arm spring)
I need to know how that thing goes in there, my manual says on carb two, but that's it, so any help would be greatly appreciated.
Old Feb 15, 2010 | 07:37 AM
This should show you how it's supposed to go. Disregard how dirty the carbs are, I can assure you that they don't look that way now. This was a before picture.
Old Feb 15, 2010 | 11:11 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
What's really depressing about dirts carbs is that his "dirty" ones are my clean ones.
Old Feb 15, 2010 | 01:24 PM
dyracuse's Avatar
thanks, I had to take a really good look at it and see what was different, finally figured it out and got it back on. They aren't complicated, but there's a lot of stuff that has to be just right. I'm going to the shop today to put together an easy access synch system today and pick up a band clamp, so hopefully I'll have the things together in a week or so. What I'm wondering is does the length of the tube affect how much vacuum the gauge "sees"? Like if carb one's hose is 1 foot, and carb 2s hose is two feet, will that affect the vacuum enough that I wouldn't be able to calibrate it properly?
Old Feb 15, 2010 | 06:35 PM
I think that it would effect the responsiveness of the sync gauge. If your engine is running at 1200 RPM, half of them are intake cycles, so 600 per minute. Divide that by 60 seconds and you get 10 intake vacuum pusles per second. Divide that by 4 cylinders and you get 2.5 intake vacuum pulses per second. The hose that you attach has to be able to transfer that fluctuation in vacuum to the gauge. I think that how long the hose is will affect how stable one gauge is compared to the other. One might be jumping wildly and the other only moving slightly.
To be safe, I'd make them the same length. Vacuum hose is pennys a foot. No need to be frugle there.
Last edited by IDoDirt; Feb 15, 2010 at 07:43 PM. Reason: Corrected math... thanks interactive (thought it seemed high)
Old Feb 15, 2010 | 06:47 PM
intiractive's Avatar
1200 rpms = 600 intakes per minute, divided by 60 seconds = 10 per second per cylinder.
4 cyl engine = one intake per half RPM. (2 revs for 1 intake for 1 cylinder. every 2 rpms each cylinder intakes once. being 4 cylinders, one cylinder intakes every half rpm. at one rpm, 2 cylinders have intaked.)
10 per second per cylinder at 1200 rpms = 40 intakes per sec for the engine. (all 4 cylinders combined)
Old Feb 15, 2010 | 09:10 PM
dyracuse's Avatar
lol, it's not frugality, more of a space concern, otherwise carbs one and two will have hoses wrapped in circles, doesn't look neat. I'm wondering I can't tell from the pic, is the square hook on the se arm, or is the round hook on the se arm?
Old Feb 16, 2010 | 07:11 AM
OK, I stand corrected again... thanks intiractive. Pay no attention to the man behind the curtain...
As for the spring, IDK. I'll check tonight, but I don't think it really matters. I would think the square one is on the carb body. I guess we'll see.
M1ke
Mar 23, 2013 04:52 PM
Napoleon Complex
Nov 29, 2011 10:30 PM
Juliet
Feb 18, 2008 12:05 PM
jaynd
Feb 9, 2008 04:56 PM
