red light on speedo
Old Dec 13, 2005 | 05:35 AM
FoolishlyMad's Avatar
Default red light on speedo
whem i turn my ignition on, on my 01 cbr 929 a red light appears and flashes in the same sequence over and over again, the light also appears when i ride although it is a consistant light with no flashing at all. would anyone be able to point me in the right direction as to how i go about fixing this problem i have, it has just turned summer here in australia and i just wanna ride but don't want to destroy my bike at the same time, could someone please help??
Old Dec 13, 2005 | 09:23 AM
Quagmire's Avatar
Default RE: red light on speedo
Well, if it is the rectangular shaped red light on the dash (next to the high beam indicator), that would be your Fuel Infection system warning indicator. Or at least that is how it is on the F4i. Read your owners manual and it should explain it to you. The light should always illuminate upon start-up (of ignition sequence) to let you know that the bulb is working. After the initial appearance (start-up) it should not come on unless there is a manfunction in the F.I. system. Find out what code it is flashing (i.e. 2 quick pulses, pause, then 3 quick pulses). If there are other codes that are present, it will follow in sequence. Annotate the code(s) then call your Honda dealer (Or find a mate with a CBR929 service manual) and it will tell you what problem the CPU has detected.
P.S. Stay away from the beaches down there, it looks pretty hairy on the news.
Old Dec 13, 2005 | 09:34 AM
doncollins's Avatar
Retired Administrator
I replied to this on the other thread you posted.... here it is again.
The MIL (malfunction indicator lamp) is the only light with a code system that I know of. Do you have a flash sequence? Count it and we can see what it says. The 600RR codes go up to 49 flashes... so be ready to count.
Just kidding… when the light stays lighted for 1.3 seconds it’s equivalent to ten blinks. So if you see 4 long blinks (1.3 seconds) and 9 short flashes it’s 49. #4 secondary injector circuit malfunction. I have the 929 shop manual... let me know and I'll look up the code for you.
xdaddyxspudx
May 2, 2013 03:01 AM
miksane
Oct 11, 2010 12:24 AM
Dewey0038
Oct 30, 2009 07:35 AM
SeanPMN
Sep 17, 2009 05:49 PM
themadpaki
Nov 18, 2007 01:59 PM
