Speedo Light
Old Sep 15, 2009 | 12:13 PM
SeanPMN's Avatar
Default Speedo Light
My Speedometer light went out. I know its not a fuse. Is there a simple check I can do to fix this? All the other dash lights work.
Old Sep 15, 2009 | 12:41 PM
motogpman's Avatar
u probably need a new bulb its this size 501 if i remember correctly
mine dies about 2months ago
Old Sep 15, 2009 | 02:51 PM
Preid's Avatar
How many bulbs illuminate the speedo?
Only the top half appears illuminated on my speedo.
Old Sep 15, 2009 | 02:52 PM
SeanPMN's Avatar
Do I have to tear apart the dash part to get to it?
Old Sep 15, 2009 | 03:19 PM
DRLOWZ's Avatar
There are like 8 or 9 bulbs.... hard as hell to reach up there and change too..
Old Sep 15, 2009 | 03:21 PM
rideanon's Avatar
You can do it without taking the windscreen off but i wouldn't recommend it due to it being a pain in the a$$. So, take off your mirrors and your windscreen will pop right out, then there is 3 bolts holding your gauge cluster to the mounts. once the gauge cluster if off (after unplugging the wires) you will need a very small screw driver (fillips i believe) to take off the **** on the left side that resets your trip mileage. once that bad boy is off the block shroud will come right off and then you can take it from there!
Old Sep 15, 2009 | 05:40 PM
SeanPMN's Avatar
Yeah, I got none at all on my speedo. the tach and all the turns and stuff work though. thanks for the input.
Old Sep 15, 2009 | 06:27 PM
DRLOWZ's Avatar
have fun. and be prepared for a fun time....
Old Sep 17, 2009 | 05:49 PM
SeanPMN's Avatar
Well just did it. I CAN SEE!!!! I found that after I changed nearly them all, the tach and speedo, I reassembled it and found that the temp light went out. DANG IT!!! Oh well, deal with it next. Thanks for the input.
xdaddyxspudx
May 2, 2013 03:01 AM
miksane
Oct 11, 2010 12:24 AM
Dewey0038
Oct 30, 2009 07:35 AM
themadpaki
Nov 18, 2007 01:59 PM
FoolishlyMad
Dec 13, 2005 09:34 AM
