raer rim problem
Old Mar 9, 2005 | 07:03 PM
CivicRacerX7's Avatar
Default raer rim problem
after having a bew rear tire put on my 94 cbr 900rr I noticed some scrubbing in the rear
to make a long story short the cbrake disk is rubbing a housing
is there supposed to be a wheel spacer/bushing on BOTH sides of the rim or just one?
mine only has a spacer on the chain side and there isnt one on the other is there supposed to be one there to space the housing back a little?
Old Mar 10, 2005 | 03:36 PM
Default RE: raer rim problem
purchased and installed a spacer man it was dangerous riding withotu that in there
Old Mar 12, 2005 | 06:43 AM
mach9's Avatar
Did you pull the rim yourself or did the shop do it? If it went in with it, and came out without it, and they did the work I would be pretty damn hot. Its your *** getting the skin grafts if the **** hits the fan cause something goes wrong due to a unfocused mechanic. If you did the work, however, your bad . Lets make sure we keep the shiny side up. Peace.
Old Mar 12, 2005 | 01:24 PM
no it was the shop definantly
Im just glad I noticed some harsh rubbing back there and got it all worked out before something BAd appened
Old Mar 13, 2005 | 01:20 AM
mach9's Avatar
Well I sure as heck wouldnt pay for the mounting and balancing of the tires! And thats at the minimum!
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
tman2
Feb 4, 2006 02:34 PM
