can I run a bigger raer tire on my 2002 cbr 600
Old Jan 31, 2006 | 04:14 AM
tman2's Avatar
Default can I run a bigger raer tire on my 2002 cbr 600
Hello , folks, just got my first bike 02 cbr 600 f4i. I do have a question on weather I can put a 190/ 50 17 tire on the bike being stock I know it is suppose to have 180/ 55 17. can someone help me with this issue? thanks[X(]
Old Jan 31, 2006 | 07:17 AM
NINE2NINE's Avatar
Retired Mod
Default RE: can I run a bigger raer tire on my 2002 cbr 600
first off, welcome to the site. as for the tire issue, a 190 will more than likely fit onto your rim. hell a 200 might even fit. but i would definately recommend against either one. if your bike came factory with a 180 then that is what i would continue to use. the bike is meant to perform the best when using the stock size tire. your steering would be slower and your tire wear would be uneven. if you are not an aggressive rider and you only want the bigger tire for the look, then it would be ok. but then again who buys a sportbike to cruise around on just to look cool. just my totally biased one sided thoughts.
Old Jan 31, 2006 | 07:39 AM
doncollins's Avatar
Retired Administrator
Hello & welcome to the forum tman2.
Nine2nine isn't bias, he's educated. Using a tire that is bigger than the rim calls for is not good. You don't even get the full width of the larger tire because you're squeezing it on the rim. Then you're reducing your contact pad and really messing things up.
No doubts about it, stick with the 180.
Old Jan 31, 2006 | 07:43 AM
NINE2NINE's Avatar
Retired Mod
here is a link to a thread started by another member with the same question. there is alot of info and links in there. hopefully it will help
Old Jan 31, 2006 | 12:43 PM
pitsvtec's Avatar
Listen to the boys...BTW
Hello & Welcome!!
Old Jan 31, 2006 | 04:55 PM
L8X's Avatar
L8X
welcome! dont change the tire.
Old Feb 4, 2006 | 02:34 PM
josho66's Avatar
Welcome. Glad you got your answer.
mitchedwards81
Apr 18, 2014 01:25 PM
Kat-Tee
F2 Tech
Jul 22, 2010 10:07 PM
paddysasausage
Oct 27, 2007 08:14 PM
gmejr
Mar 3, 2007 10:48 PM
greymustang
Jan 6, 2007 06:24 PM
