raer rim problem
raer rim problem
after having a bew rear tire put on my 94 cbr 900rr I noticed some scrubbing in the rear
to make a long story short the cbrake disk is rubbing a housing
is there supposed to be a wheel spacer/bushing on BOTH sides of the rim or just one?
mine only has a spacer on the chain side and there isnt one on the other is there supposed to be one there to space the housing back a little?
RE: raer rim problem
Did you pull the rim yourself or did the shop do it? If it went in with it, and came out without it, and they did the work I would be pretty damn hot. Its your *** getting the skin grafts if the **** hits the fan cause something goes wrong due to a unfocused mechanic. If you did the work, however, your bad . Lets make sure we keep the shiny side up. Peace.
dewthedoo05
09-04-2007 09:32 PM
