Q for Resistor of replacement signals
Old Feb 9, 2009 | 10:57 PM
TikkiTakki's Avatar
Question Q for Resistor of replacement signals
Hey guys,
*I parked the bike when I got to class today and realized that somewhere on my trip my stock Front Turn Signal Lens Cover had fallen off exposing the bulb. So I went to the honda store to see how much a 2cent piece of plastic would cost me...11 bucks
**I went to ebay and bought some half decent LED turn signals for a few more bucks.
***My question is what kind of resistor size will I have to attach to the line to keep the blinker speed the same? ebay says that these will be running 12volt(duh) at 1 watt.
Thanks!
Old Feb 10, 2009 | 10:52 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
If you still have incandescent bulbs for rear turn signals, you may not need resistors. I'd hook it up and see if you get hyper-flash before buying them. The bulbs in the rear may provide sufficient resistance so as to not effect the relay.
Old Feb 10, 2009 | 10:57 AM
redzintimidator's Avatar
I would stay away from non-inductive resistors. Instead i would look into a variable load or LED signal relay, should cost around $5..and doesn't put out tons of heat like the resistors do.
Old Feb 10, 2009 | 12:43 PM
MidnightG35X's Avatar
What is a non-inductive resistor? More specifically the non-inductive part....
Old Feb 10, 2009 | 02:45 PM
krash's Avatar
yeah, I personally stayed away from the resistors, too much of a pain. just buy the led relay. although $5 is a awfully cheap. when I bought mine it was a direct plug in for the factory relay, but it was $17. and you have to take the front fairing off the F4i to get to it.
10secdream
Jun 20, 2012 10:33 PM
abelg
May 11, 2009 06:11 AM
turboryan
Apr 30, 2009 10:25 AM
Micah_Potter
May 29, 2008 08:41 AM
shoortbuss
Feb 2, 2008 09:00 AM
