Possible Coolant issue?
Old Nov 25, 2012 | 03:49 PM
CBRfenatic93's Avatar
Default Possible Coolant issue?
Its been awhile since ive been on but i need some help now.
I washed my bike today and started it up after to go ride. It started right up but sounded like it was cold so i let it sit for a few minutes. No temperature popped up on the gauge and it kept making a sound like (vrump vrump vrump vrump). I blipped the throttle and it died. I started it again and hit the throttle and smoke started to come out of the exhaust. I shut it down and took a look and noticed that my coolant bottle has a hole in the top portion of it with maybe 1/2 inch of coolant in it. I take the radiator cap off and it is bone dry in there. It ran fine 2 days ago and hasnt been ridden since.
Im wondering if i got a hole in the coolant bottle and over the past 2ish weeks(last time i did my inspections) the coolant has been evaporating from it and now it has caused something to get heated and a seal maybe is screwed?
The last time i rode it the temperature was never above 180.
Any idea?
Old Nov 25, 2012 | 04:13 PM
gotcbr's Avatar
If its as you describe, you're prob ok. Just replace the bottle, fill it & system w/ fluid, & test.
Old Nov 30, 2012 | 08:11 AM
Fobwareagle's Avatar
Thumbs up
+1^^
Old Dec 1, 2012 | 02:06 PM
Alright so I fixed the bottle and started to flush the system. I recovered about 2qts from the bike on the first drain so it wasn't empty like I thought. I filled it with distilled water and drained it again. i only keep getting 2qts out which is about what I pour in. The manual says the cooling aystem capacity is 2.99qts. Am I missing something here?
Old Dec 1, 2012 | 02:10 PM
gotcbr's Avatar
There will some residual in the system. Since you've flushed it twice, top it off & check level per manual. Run & check again. GTG.
Old Dec 1, 2012 | 02:18 PM
Awesome. Thanks for the quick reply.
srp2035
Oct 2, 2012 08:56 PM
Parnavaz
Jun 9, 2012 11:58 AM
itlnF4I
Jun 7, 2011 07:19 PM
JEFF4i99
Mar 24, 2011 07:54 PM
StangLou
Sep 1, 2007 08:49 AM
