coolant temp issue
Old Jun 6, 2011 | 10:44 AM
itlnF4I's Avatar
Default coolant temp issue
a week ago i swapped my transmission gears, temp gauge worked perfectly before i took the motor out, now everythings good, bike works fine except for the temp gauge now, itll jump like 2-10° up or down from the number its showing, ex: showing 158° it would jump to 167° then back down to 160° then back to 168° and so on. im assuming its always actually at the highest temp it jumps to, just wondering if anyone else has had this problem
Old Jun 6, 2011 | 10:53 AM
jeffjones's Avatar
Does it happen when you go from riding to stopping or just sitting there?
Old Jun 6, 2011 | 01:25 PM
itlnF4I's Avatar
all the time. standing still and riding
Old Jun 6, 2011 | 04:20 PM
yunebug's Avatar
Could be a misconnection at the sensor. Quick shorts and unreliable signals could be going to the ECM and displaying different numbers. I doubt it's the actual coolant that's fluctuating this wildly.
You can find out to see if the fan kicks on and off at the 200~ degrees area as the temp fluctuates I suppose. Go for a ride, come back and let it climb. If the fan kicks on and off as randomly as the temp is being displayed, you have your culprit.
Old Jun 6, 2011 | 04:25 PM
yunebug's Avatar
Old Jun 7, 2011 | 10:21 AM
itlnF4I's Avatar
fan is hard wired with a fuse to a switch, and i doubt the sensor is fluctuating like that too. im pretty sure i just remembered the sensor connection was greasy when i put it back on in a hurry. lol
Old Jun 7, 2011 | 07:19 PM
yunebug's Avatar
Oh haha once you clean out the grease, I'd imagine things will return to normal. :0)
Problem solved!
VR4Mit3000GT
Jun 15, 2013 05:55 PM
ceracer33
Jun 19, 2008 09:46 PM
SHugo
Mar 20, 2008 08:19 PM
