Need help troubleshooting...
Old Jun 6, 2011 | 07:29 AM
bmorecbr's Avatar
Thumbs down Need help troubleshooting...
here goes:2001 F4i ~25,000 miles. I was our riding and my fuel light came one. I stopped for fuel, filled up and rode off. About a mile or so later (around the same time the fuel light reset and went back off) the red light came on and the bike cut off. All electronics were were still working including the headlight. I pulled the tank off and checked all the connections around it and everything seemed in order. Also tapped on the fuel pump, no luck. The engine doesn't turn over and the fuel pump does not prime when i turn the bike on. Any suggestions on where go from here??
Old Jun 6, 2011 | 08:18 AM
Survivalism's Avatar
Check your fuses if you have not yet, thats now the very first thing i check when anything goes wrong out of the blue.
Old Jun 6, 2011 | 08:38 AM
Kuroshio's Avatar
Things that would cause the pump not to prime
  • Fuses
  • Bank Angle Sensor
  • Killswitch
If I missed any, someone else can add it. Killswitch could be faulting. Somewhat common for the solder in it to break after years. Fuse should always be the first check though. BAS will do it as well. Kickstand sensor won't stop the pump from priming so that's out.
Till you get the pump to prime, you won't get it to fire
Old Jun 6, 2011 | 10:43 AM
bmorecbr's Avatar
thanks for the quick response, going to start working on it as soon as i get off work
Old Jun 6, 2011 | 04:22 PM
bmorecbr's Avatar
aaaand it was the bank angle sensor fuse. I can't believe i didn't check the fuses first. Thanks for the help again!!
Old Jun 6, 2011 | 04:24 PM
yunebug's Avatar
Just on the off-chance this might happen:
Did anything drop into the tank while fueling?
The fuel light went off at the same time the FI light came on, right? Could this mean that the ECM switched the fuel line so that the pump was getting fuel from the regular spout (and not the reserve spout further down in the tank) and then something got sucked in (or is blocking the regular spout)?
Old Jun 7, 2011 | 04:39 PM
bmorecbr's Avatar
Question
I had just refueled but as far as i know nothing fell in the tank. If it did wouldn't that just stop the fuel flow and cut the bike off as if i ran out of fuel? OR would it cut the bike off and blow the bank angle sensor fuse as well??
Old Jun 7, 2011 | 07:18 PM
yunebug's Avatar
My worry was that whatever piece of something it was, it was sitting on/in the normal spout when it fell in the tank. Then when the ECM switched from the reserve spout to the normal spout, fuel was cut off (hence te FI light) because of the blockage.
Not too familiar with the normal vs reserve spout programming in the ECM. Someone correct me? <:0)
Old Jun 7, 2011 | 07:29 PM
Kuroshio's Avatar
Popping a fuse is electrical. Always. A blockage will not cause a fuse to blow.
I think the fueling part is coincidental since the blown fuse was the cause. Sounds like you have something grounding out and it was coincidence that you just filled up. More likely something in the road caused a short somewhere
02TrickFlowGT
Sep 15, 2011 03:34 PM
Blove1991
Jun 22, 2009 04:32 PM
maldy21
Sep 20, 2008 11:18 PM
volcomrr
Aug 19, 2008 03:49 PM
boriquaalexr
Sep 28, 2007 03:57 PM
