Coolant Issue
Old Mar 24, 2011 | 07:13 PM
JEFF4i99's Avatar
Default Coolant Issue
So here's a curious one. My bike is running normal temps, no problems and such, and then bam twice when I turn it off, some coolant spills onto hot parts then smoke. Not losing any when she sits there though, just right when I turn it off.
I was low and changed it, and now we have this problem.
I think it may need a good strong flush, more thorough than what I had done initially. Is the coolant coming from the spill bolt?
I'm hoping it's nothing serious, she is running cooler than normal and stuck in traffic, normal. I'm concerned but super confused, and didn't find something quite like it in my searches. Also, on my way to class (where I am now), it didn't happen this last time but did this morning. Any help folks?
Thanks!
Old Mar 24, 2011 | 07:19 PM
600F4inoober's Avatar
If the temps are fine....then you simply overfilled the system it sounds like...wheres the leak coming from? Check that you bleed/burped the system and that the cap is correctly secured down
Old Mar 24, 2011 | 07:20 PM
JEFF4i99's Avatar
Low on the motorcycle, but not quite as far back as the drainage hose.
Old Mar 24, 2011 | 07:23 PM
Check all your hose clamps..
Old Mar 24, 2011 | 07:54 PM
JEFF4i99's Avatar
Yeah, that's the plan for the weekend.
CBRfenatic93
Dec 1, 2012 02:18 PM
srp2035
Oct 2, 2012 08:56 PM
Parnavaz
Jun 9, 2012 11:58 AM
itlnF4I
Jun 7, 2011 07:19 PM
StangLou
Sep 1, 2007 08:49 AM
