Please someone who is good with electrical HELP!
Old Jun 15, 2021 | 04:41 PM
cbr6002341214's Avatar
Default Please someone who is good with electrical HELP!
2012 Honda Cbr 600rr
Hi, so left my bike over the winter. Changed battery for new season, upon starting bike it run a little rough and than cut off. Found F/I fuse had blown. Replace fuse, bike starts runs for 2 mins and than fuse blows again. This process can be repeated and bike will do same thing every time.
Took apart fairings, and saw a minor fray in the main harness wire. I changed the entire main harness wire complete with new fuse box. Start bike and same thing, fuse pops!
Is the F/I fuse for the fuel injector? Or is another component causing that fuse to pop? Please help I have spoken with multiple mechanics and they just recommend to keep changing parts/wire harnesses until problem solved. If I do that I will be more into my bike than its worth.
Any ideas? Anyone have the same issue? Please help! I will literally pay for the advice, I am so lost on where to go from here.
Thank you in advance!
Old Jun 18, 2021 | 02:31 PM
Do you have the shop/service manual for your bike year make and model? I don't have a wiring diagram for your bike so can't offer any real advice. If you can get the wiring diagram, locate the fuse on it and identify everything that is down stream from it. Unplug all those things and plug them back in one by one until the fuse blows again. Should work by process of elimination.
Old Jun 20, 2021 | 03:35 PM
Boufon1's Avatar
Wink
Hi fella,can you turn the ignition on with the kick stand down?does the f/I light blink?if it does these are fault codes here is a list of them,
Got these off another forum,hope it helps 👍
Gb Boiy
Feb 6, 2019 02:46 PM
my_honda
Oct 29, 2008 12:15 AM
bru926
Dec 29, 2006 12:48 PM
jbriley3
Jul 24, 2006 03:40 PM
dbgmpd
Jun 15, 2006 12:49 AM
