Dash Dies when riding
Old Jan 7, 2019 | 09:00 AM
Gb Boiy's Avatar
Default Dash Dies when riding
Hey guys im new here coming to seek help.
I own a CBR 600 F3 1999 well the problem I have with the bike ever since I bought it is that when Im riding the dash dies, its like it loses all the power but only to the dash, I have to stop and remove a fuse and then it comes back alive and it works fine. What could be wrong with the bike ?
Old Jan 9, 2019 | 06:37 PM
heanoid's Avatar
which fuse are you removing .. check the fuse holding connections for that fuse and the wiring that runs to it for breaks splits etc i had to replace the back of my clocks as water had got in and buggerd up the connectors
Old Jan 15, 2019 | 09:17 AM
2andrewd's Avatar
if pulling a fuse out and placing the same one back into the socket, what is essentially happening there? you've reseated the fuse. the contacts could be dirty in the fuse box or it's somehow working itself loose. clean the contacts or wait until it happens again and instead of pulling the fuse, push the fuse. then you'll know
Old Feb 6, 2019 | 02:46 PM
Matt Harvey's Avatar
I'm getting it intermittently on my F4i at the minute as i do about 80 miles a day in the UK & it's just rain & snow at the moment. I have got corrosion showing in my connector blocks from all the moisture so occasionally it breaks the circuit... yours sounds similar..,, check for corrosion to the pins in wiring harness connection blocks & fuse holders & gently clean until all are clean & shiny again, after putting them back together spray with a water repellent regularly like wd40..
NE1000F
Nov 16, 2018 09:00 PM
FuzzyWuzzyBear
F2 Tech
23
Mar 24, 2010 07:09 PM
my_honda
Oct 29, 2008 12:15 AM
taymax14
Jul 3, 2007 12:12 PM
dbgmpd
Jun 15, 2006 12:49 AM
