plate light
Old Jun 12, 2007 | 10:29 PM
isolated1523's Avatar
Retired Super Moderator
Default plate light
So i got stopped down here in AL by a state boy for having my plate improperly mounted (guess it was too far under the tail for him?) and for not having a plate light. So i fixed the plate problem, and picked up a plate light that doesn't look too bad....my question is, where should i wire it to? My first thought was the taillight, but i have the CA integrator and i'm not sure about hooking it up with it....are the rear running light and brake light seperate wires/circuits? Or will the plate light (which is a 12V LED bar, by the way) flash brighter when i hit the brakes? lol
Any other ideas where to hook it in? I need it to come on when the bike is on, so i don't wanna hook it straight to the battery.
Any help is appreciated!!!!
-Adam
Old Jun 12, 2007 | 10:43 PM
Mad's Avatar
Mad
Default RE: plate light
Should be able to hook it up to your running lights. I don't see why you couldn't. The LED won't flash brighter.
Old Jun 12, 2007 | 11:11 PM
CBR1000's Avatar
You should find your original plate light leads and use them. When you removed your mudflap and
changed over to the CA there is additional wires for the light which you must of cut. They will be
easy to find if you take off your rear plastic. They will be the ones not connected to anything.
Old Jun 13, 2007 | 12:46 AM
Ricepowered01's Avatar
yea cbr1000 has the right idea. i cut the plug off my stock plastic piece for the tag light and wired it to the plate light then plug it in to the plug on your bike works like a charm
6doubleohf3
How-To: Mechanical
May 1, 2009 01:59 AM
ulosetoo
Mar 21, 2008 12:24 PM
tomvoy
Oct 18, 2007 10:32 PM
Brennan
Jul 16, 2007 05:05 PM
Ueafa
Jun 2, 2007 01:13 AM
