Another waterpump issue...
Old May 22, 2007 | 02:35 PM
hill1513's Avatar
Default Another waterpump issue...
Well, I figured I'd start a new thread on this. My F4 is still overheating, but now I'm noticing fluid coming from the telltale (weep) hole and it's grey. I'm thinking this is metal shavings. I'm thinking I shouldn't ride my bike til I get a new pump, change the oil, and change the coolant. Would I be right? I'm assuming this will also take care of my overheating at speed problems.
Thanks for all the help so far!
Old May 22, 2007 | 02:47 PM
hill1513's Avatar
Default RE: Another waterpump issue...
Here's a pic of the stuff coming out of the weep hole...
Old May 22, 2007 | 04:14 PM
Tahoe SC's Avatar
uh oh...looks like oil...or grease...you sure it's not chain fling that leaked down from the sprocket cover?
Old May 22, 2007 | 04:30 PM
cozye's Avatar
did you by chance use regular "car" antifreeze in this bike ?
Old May 23, 2007 | 12:26 PM
hill1513's Avatar
Tahoe - It could be. But regardless, there is definitely a trail of fluid (not much) coming from the weephole.
Cozye - After it initially overheated, I used distilled water with vinegar to flush it out and see if that was the problem. Then I went to a "car" 50/50 mix. Not that this argument will matter, but the stuff I used is for all makes/all models. Meaning it works in any coolant system with any style/type of radiator. I don't see why this would cause the bearing or seal to fail in the pump.
BTW, I never checked the weephole before I did in the pics.
Old May 23, 2007 | 12:34 PM
Tahoe SC's Avatar
pull it apart mang...if it's weeping you gots to replace it anyway.
Old May 23, 2007 | 02:03 PM
hill1513's Avatar
That's what I figured. Oil and coolant are being changed again too. I think I have 40 miles on this oil change andmaybe 10on the coolant. I just hope this was my original problem, seeing as I never checked the weephole, only took off the cover.
Old Jun 13, 2007 | 05:13 PM
hill1513's Avatar
Justletting ya'll know...it turned out to be the water pump.
J187
Jul 19, 2022 09:04 AM
Dan1220
Sep 21, 2020 10:19 AM
Ricecooker
Feb 17, 2014 02:48 AM
black93lx
Jun 23, 2007 02:27 PM
Dan1220
May 18, 2007 12:19 AM
