license plate light?
Old Jul 14, 2007 | 03:10 PM
Brennan's Avatar
Default license plate light?
im trying to intall the white led light for my license plate and the directions say connect the positive to the brown wire and the neg to the green wire but this isnt working if anybody have any advice that be great, im trying not to get pulled over for something stupid
Old Jul 14, 2007 | 04:17 PM
baxsom's Avatar
Default RE: license plate light?
are you getting power to these wires
green is ground
hook up a volt meter to the brown and green wires and turn on the key
if you arent getting voltage you probably blew a fuse
Old Jul 15, 2007 | 03:55 AM
Blue Fox's Avatar
Retired Moderator
Your LED is probably polarized, try switching the wires and see if that works.
Old Jul 15, 2007 | 08:17 PM
thecannibalchef's Avatar
led is polarized for sure. don't hook it up backwards. green = ground on the bike, and black should = ground on the led. but you probably just shorted the positive to ground and blew a fuse. check that before you do any diagnostics.
Old Jul 16, 2007 | 05:39 AM
Blue Fox's Avatar
Retired Moderator
What colors are the wires on the LED? Are they red/black or different? All polarized LED's I've ever dealt with just have two wires (usually the same color or one striped). If it didn't work one way, I switched the wires and it would light right up......and never had a problem with blowing an LED, ever.
Old Jul 16, 2007 | 05:05 PM
Brennan's Avatar
thanks everybody for the advice i got it to work, the postive from the led just had to hooked up to a different wire than what the directions said i just had to try different combos till it worked
TwistedFire13
Oct 3, 2012 01:27 AM
kup125
May 22, 2011 10:05 AM
6doubleohf3
How-To: Mechanical
May 1, 2009 01:59 AM
maximus3
Sep 16, 2006 11:57 AM
530Chain
Mar 22, 2006 07:19 PM
