No power
Old Apr 23, 2013 | 06:47 PM
msiboloski's Avatar
New Member
Default No power
My wife has an 03 CBR600RR and somehow hooked the battery up backwards, I've replaced the 30A fuse in the battery box and the battery has 13 Volts but turn the key and no joy. I have checked the fuses on the left side and there all good but cant find any others, any ideas where else I can look?
Old Apr 24, 2013 | 06:53 AM
wheelnut's Avatar
Welcome Crew
to start with disconnect the battery and try another if you have one just to elliminate you havent naffed your battery,if the problem is sill there check the leads from your battery to the starter relay, this is the box the 30amp fuse was in,if you have a multimeter you can check the positive carries power to it and you can check the negative has continuity by checking it on the ohms scale, if this is ok next step is the relay its self,
hope this helps to start you off.
coolbluedab
Feb 7, 2014 07:13 PM
romanboy
Jan 19, 2013 12:53 AM
__Z__
Jul 14, 2010 10:00 AM
Karmakazi
Sep 29, 2009 09:58 AM
Certified Ryder
Nov 12, 2007 10:13 PM
