My fuel pump doesn`t run when I turn the key on
Old Mar 27, 2007 | 07:21 PM
A 929RR RIDER's Avatar
Default My fuel pump doesn`t run when I turn the key on
I replaced the fuel pump, that wasn`t the problem.I got power to the plug(going to the fuel pump).I don`t think I have a grounding problem! I checked that and it checked good.I`m being told it could be myECM or ECU(the brain).The engine does crank.Can anybody help me??? It`s a 2001 cbr 929rr.
Old Mar 27, 2007 | 07:47 PM
Jaybird180's Avatar
Default RE: My fuel pump doesn`t run when I turn the key on
Did you verify the kill switch? Those things can go out on you.
Old Mar 27, 2007 | 11:59 PM
DWT74's Avatar
Have you had the speedo off or unplugged and if so check it, i know on a 600RR they will crank over til the battery is dead without it hooked up. Then there are ignition fuses.
Old Mar 28, 2007 | 12:31 PM
Charger's Avatar
Once while riding my 954rr, my bike lost power. Everything had been fine prior to that. Turning the key to On, the fuel pump wasn't going. The fuse had blown. Put the spare in and it started right up as normal. Didn't have a problem after that.
ELREYNIKKO
Aug 13, 2013 10:57 PM
americancbr929rr
Aug 2, 2012 03:32 AM
zach929
Feb 6, 2012 07:25 PM
Stunt'n70f4i
Sep 6, 2010 10:52 AM
A 929RR RIDER
Mar 27, 2007 08:08 PM
