Won't turn over? Fuel pump doesn't even prime
Old Nov 6, 2006 | 11:59 PM
zach929's Avatar
Default Won't turn over? Fuel pump doesn't even prime
Hey Ive got a 2001 CBR929RR. I recently moved to East Lansing and have been storing it outside with a cover. One morning when I went fire her up nothing happened. The fuel pump does not even prime when you turn the ignition key on. When you hit the start button the headlight goes out but nothing else happens....I have checked the battery and all fuses and that does not seem to be the problem....Can moisture cause something like this from being outside?
My first thought after checking the fuses and battery was the the ignition switch has gone bad?????
or that there is some kind of relay that tells the fuel pump and starter to engage when the ignition key is turned??????
Any similar problems out there?????
Any suggestions?????
Thank you
Zach
Old Nov 8, 2006 | 10:38 PM
svtsnake's Avatar
Default RE: Won't turn over? Fuel pump doesn't even prime
Check the fuses, ignition switch, kill switch, ground for the fuel pump. Any one of these things can cause the pump to not work. Thre is a relay that relates to the fuel pump. It is called the fuel cut relay. If you want, PM me your email address and I can send you a copy of the service manual, it should help you out.
Old Nov 9, 2006 | 02:49 AM
stuntin's Avatar
Had the same thing with my 929 it turned out one of the wires got seperated from the kill switch, 5 min later with a soldering gun and its good as new
Old Jan 31, 2012 | 09:21 PM
Cbr929rrrr's Avatar
yeah some time is you mess with the ignition it burns out the diode that is inside of it it is only supposed to have 9v to 8v on it any more or less and the fuel pump will not prime im looking right now for one but cant seem to find one that works it called a zenard diode i thing. its and its a theft system so someone cant hot wire your bike with a hot wire but they can take it if you have a 9v battery that how i have been starting my bike tell i can find the diode or a ignition in my price range.
Old Feb 2, 2012 | 09:28 AM
crazie929's Avatar
Svtsnake is right. To me it sounds like a faulty ground.
Old Feb 2, 2012 | 09:30 AM
crazie929's Avatar
Was it working fine before?
Old Feb 2, 2012 | 09:43 AM
74demon's Avatar
this thread is over 5 years old. im sure he got it figured out by now....lol
Old Feb 2, 2012 | 10:18 AM
crazie929's Avatar
Lol woops. He should've posted a solution at least.
Old Feb 2, 2012 | 10:23 AM
74demon's Avatar
he should have, but not everyone does. the lack of posting solutions and final outcomes kinda bothers some of us that spend the effort trying to help people around here. oh well, on to the next bike problem....
Old Feb 6, 2012 | 07:25 PM
Cbr929rrrr's Avatar
the next problem i got one my remote start is not working i cant get the system to prime when trying to start the bike with the remote it turns over but i know its not geting gas key works fine. any ideas ? what is the blue and orange strip wire?
Ls1Mx5
Jan 5, 2014 04:01 PM
ELREYNIKKO
Aug 13, 2013 10:57 PM
adamw89_2000
Jul 8, 2010 05:15 PM
A 929RR RIDER
Mar 28, 2007 12:31 PM
A 929RR RIDER
Mar 27, 2007 08:08 PM
