My fuel pump doesn`t run when I turn the key on
Old Mar 27, 2007 | 07:36 PM
A 929RR RIDER's Avatar
Default My fuel pump doesn`t run when I turn the key on
I replaced the fuel pump that wasn`t the problem.I have power going to the plug going to the fuel pump.I checked the ground the best that I could everything checked ok.I was told it was my ECM or ECU (the brain).Can any body help me.It`s an 01.
Old Mar 27, 2007 | 08:08 PM
1FAST929's Avatar
Default RE: My fuel pump doesn`t run when I turn the key on
i had a buddy witha 954,and he had the same problem.it was cuzz the wire in the ecu plug
had been pulled loose from the plug and the pump would not get the signal from the ecu to kick on...i hope this might help u trace down ur problem..good luck.ride safe ride red
ELREYNIKKO
Aug 13, 2013 10:57 PM
americancbr929rr
Aug 2, 2012 03:32 AM
zach929
Feb 6, 2012 07:25 PM
Stunt'n70f4i
Sep 6, 2010 10:52 AM
A 929RR RIDER
Mar 28, 2007 12:31 PM
