Lowering F4i with link?
Old Mar 27, 2011 | 12:30 PM
woodypk's Avatar
Will I have to remove the fairings to do this?
Old Mar 27, 2011 | 02:07 PM
ocarlos5's Avatar
Not at all. Just remember to loosen the top bolts slowly. One side at a time. If you loosen them too much, your bike will drop all the way down to the front wheel fairing assuming you're not using a hoist, which I didn't use without any problems.
Old Mar 28, 2011 | 10:44 AM
woodypk's Avatar
Ok, thanks for the help and thanks to all who posted. When I get this done I will let you know how it went.
Old Mar 20, 2019 | 02:12 PM
Joshua Weems's Avatar
Originally Posted by ocarlos5
find a way to suspend the subframe, using a hoist or something similar. This is to take the load off the shock. Locate your rear shock and unbolt the lower mounting nut on the shock, along with the other two nuts on the link plate. Remove link plates and install new ones. I bolted the dogbone on the bottom first, then the middle bolt to the swingarm, then the lower bolt on the shock. Torque to 33 lb-ft. I didn't use a hoist. I had my bike on the kickstand and used my shoulder to lift the tail. Not a smart way to do it because you put a lot of stress on the tail fairing and you can tip your bike. This is a very quick and easy procedure IF you have the right tools.
how did you get the dog bone link out I cant get a wrench in there to do it and I'm stuck at the moment
subyman1440
May 7, 2012 06:26 AM
lilbit4517
Jul 28, 2010 02:02 PM
Jeff1980
Nov 5, 2008 10:04 AM
colleenhixx
Jul 17, 2007 01:29 AM
SITNLOW97
Jan 15, 2007 07:02 AM
