Help lowering rear question
Old Jan 12, 2007 | 02:05 PM
SITNLOW97's Avatar
Default Help lowering rear question
OK my bike is preety damn low and the front is fine but the rear someone took out the shock/strut and replaced it with a piece od custom steel they made and it worked great besides it rides like ****...Is there anything i can do without put a air cyclinder on it, does anyone make a loweered strut for it, or can u cut ur stock one down cause i do still have it too???Thanks for all the info...
Old Jan 12, 2007 | 02:12 PM
bindelsf2's Avatar
Default RE: Help lowering rear question
i would definately put a shock on the bike and buy a lowering link for it. you can finda lowering link anywhere and they are about 95.00 on ebay or you can go herehttp://store.58cycle.com/SearchResul...+lowering+link . do a search on here thereare a ton ofthreads on lowering.
Old Jan 12, 2007 | 08:04 PM
SITNLOW97's Avatar
So if i understand correctly i can put the stock shock back on and get a lowering link and have both of them on there right?? If so can someone show me some pics of were the link mounts to??? and how it works???
Old Jan 12, 2007 | 08:55 PM
bindelsf2's Avatar
yes put a stock shock on and a lowering link. the bottom of the shock should connect to a triangular plate on the rear-most hole and the lowering link will replace the factory dogbone. from the forward most hole down to the lower mount. in this pic you can see the triangular mount that i am talking about.. hope this helps..
i did mine in about 15 minutes by myself so if you need any help feel free to ask...
[IMG]local://upfiles/7261/FCC65B51FE48421694F1AFAEFEAC36E9.jpg[/IMG]
Old Jan 13, 2007 | 10:12 AM
SITNLOW97's Avatar
Thanx bro u been alot of help...Ok so the lowering link takes place of the triangle dog bone right?? If so does anyone have any before and after pictures???
Old Jan 13, 2007 | 12:38 PM
bindelsf2's Avatar
last one..LOL it doesnt take the place of the triangle it connects from the forward hole on the triangle down to the lower mount behind the engine so you do need the triangled piece also.. i will get a pic of my setup tonight hopefully...
Old Jan 13, 2007 | 01:47 PM
PatsCBR's Avatar
The lowering link (dogbone) is longer then stock so it pivots the shock to a lower angle and height.. Very simple to install and when you get one you'll see how it works..
Old Jan 13, 2007 | 01:59 PM
bindelsf2's Avatar
+1
so i founda pic that should help... the lowering link would replace the dogboneshown and the bottom of the shock would connect to the rear hole. hope this helps..
[IMG]local://upfiles/7261/D654C9D74652449FA4B6ED42038C29DF.jpg[/IMG]
Old Jan 13, 2007 | 03:56 PM
SITNLOW97's Avatar
Aight thanx guys sorry im new to lowering a bike but i got it now, just wondering how low can u go with a new dog bone installed???
Old Jan 13, 2007 | 05:09 PM
bindelsf2's Avatar
1.5" or 3" with the two hole link or you can buy a threaded adj. one and go any length in between.
