installed damaged masterlink help
Old May 18, 2010 | 07:36 PM
roadrash789's Avatar
Default installed damaged masterlink help
Hey guys, got a quick question. I had a chain and new sprockets installed by the local honda dealership. Anyway when they installed the masterlink they mushroomed one of the pins and it has a slight crack in it is this bad.
Old May 18, 2010 | 07:39 PM
Kuroshio's Avatar
Can you take some pics?
Not sure it really matters tho. You have a concern about how they installed the chain. Take the bike back and make them redo the master link. Prolly won't sit right in your head till you do.
Old May 19, 2010 | 11:19 AM
Yea, I will post some pics tonight.
Old May 19, 2010 | 06:49 PM
Oh well, can't get pics cause camera doesn't take good close ups. But the split in the one pin looks good but the other pin has a split about 1mm.
Old May 19, 2010 | 11:09 PM
justasquid's Avatar
Make sure its not just a mark left by the tool. If the tool has any imperfections, they will transfer to the pin. If both pins have cracks or splits, I'd not trust it. For peice of mind, replace it. its not that expensive even if you have to have someone else do it. You'd hate to have a chain come undone. Potential for crashes and cracked engine cases is far to great of a risk in my opinion.
The thing I would be concerned with is if they compressed it hard enough to split the pin, its probably way too tight. There are shims they are suppose to use to guide how far to compress the links, then they set the pins. If they went too far in setting the pins, they could have tightened up the link too much and it will wear very fast. I would at the very least loosen up the chain and get as much slack as you can. then try to pivot the master link and see how hard it pivots. If its really hard, have them replace the link.
But, pictures would be good. From your description and not actually seeing it, I'd replace it. If you can pics up, it might be a different story.
Old May 19, 2010 | 11:10 PM
A split in the masterlink, although probably won't cause any problems, you paid them to do it right. It clearly states in the maual that if there is any cracking or splits to replace the master link. There is no question here. If they give you any grief, stand your ground.
Old May 20, 2010 | 05:36 PM
Thanks guys. I'm going to take it back sat. and see if we can work something out. Cause I dont want it to be to tight and I dont want it to fly off either. Gonna bring my manual to in case they try some funny business.
Old May 20, 2010 | 05:44 PM
dohcdelsol's Avatar
did you buy the chain and sprocket and bring it to them or is it oem?
only askin is bc alot of aftermarket stuff that the dealer puts on if something goes wrong they wnt cover it and you're up a certain creek w/o a paddle. if its oem they take it back and tell them to do it over b/c its your life and if something goes wrong they will be held accounted for.
Old May 22, 2010 | 06:47 PM
Its a stealth sprocket and D I D gold series chain. I havent taken it back yet. I just decided to order a new master link for 8.95 and find a chain tool and do it myself. from here on out any work that it needs in the future im just going to do it myself .
sikgmc
Jun 9, 2009 01:50 PM
TrickyNic
Apr 28, 2008 04:05 PM
djackson812
Feb 29, 2008 07:50 AM
WiscRed
Aug 28, 2006 11:49 PM
