installed damaged masterlink help
Make sure its not just a mark left by the tool. If the tool has any imperfections, they will transfer to the pin. If both pins have cracks or splits, I'd not trust it. For peice of mind, replace it. its not that expensive even if you have to have someone else do it. You'd hate to have a chain come undone. Potential for crashes and cracked engine cases is far to great of a risk in my opinion.
The thing I would be concerned with is if they compressed it hard enough to split the pin, its probably way too tight. There are shims they are suppose to use to guide how far to compress the links, then they set the pins. If they went too far in setting the pins, they could have tightened up the link too much and it will wear very fast. I would at the very least loosen up the chain and get as much slack as you can. then try to pivot the master link and see how hard it pivots. If its really hard, have them replace the link.
But, pictures would be good. From your description and not actually seeing it, I'd replace it. If you can pics up, it might be a different story.
did you buy the chain and sprocket and bring it to them or is it oem?
only askin is bc alot of aftermarket stuff that the dealer puts on if something goes wrong they wnt cover it and you're up a certain creek w/o a paddle. if its oem they take it back and tell them to do it over b/c its your life and if something goes wrong they will be held accounted for.
