idle problem
Old Oct 29, 2008 | 06:51 PM
el bimbo's Avatar
Default idle problem
i have a 92 600 f2 cant get it to idle right i have to put it at 2000rpms so it wont turn off and its ruff pretty ruff i sould say and it gos up and down and turns off any one know what my problem might be ?
Old Oct 29, 2008 | 07:51 PM
justasquid's Avatar
Default RE: idle problem
If it just starting happening, probably dirty carbs. If its been this way, you may need a carb sync.
Also, check to make sure your carb boots are not dry rotted so they are sucking air. Take some wd-40 and spray around your carbs, especially around the mounting bootswhile the bike is running. If the rpms change while you do this, you probably have rotted boots or possibly just loose ones.
But my first guess would be dirty carbs.
Old Oct 29, 2008 | 08:06 PM
el bimbo's Avatar
well i just got the bike it didnt run it was flooded in ike and now i got it running i already cleaned the carbs i was thinking it needed the carb sync just tring to make sure cuz the plugs are new and i have fire at all plugs besides the carb sync can u think of anything else and thanks for the reply
Old Oct 30, 2008 | 08:39 AM
jonld's Avatar
Uneven Compression will also do that. Do a compression test and see what you have.
LeighUCI
Sep 5, 2008 09:55 AM
atr3yu baykor
Mar 5, 2008 12:32 AM
f4iCON
Jan 9, 2008 07:15 PM
meangreenturbo
Oct 27, 2006 12:34 PM
lksfast77
Apr 3, 2006 02:29 AM
