How to drain gas?
Old Sep 1, 2012 | 01:26 AM
redbaron1728's Avatar
Default How to drain gas?
So I blew up my F2 that has a full tank of gas, and I want it Is one of the three hoses down at the bottom of my bike the drain hose? If so how do I drain it? I also don't mind going just plain dumping the tank upside down into a bucket lol! Thanks guys
Old Sep 1, 2012 | 06:55 AM
roboto65's Avatar
Thats what I did had the tank off and removed the petcock and dumped it in a bucket then set in sun to dry out the rest of the fuel.
Old Sep 1, 2012 | 07:05 AM
jeffjones's Avatar
I got a syphon hose with a hand pump from the local car parts store for like $5 and you put one end in the tank and pump it till it starts flowing and it drains the whole tank, Worked perfect and didn't spill a drop
Old Sep 1, 2012 | 09:39 AM
Stu Pidasso's Avatar
I use my vacuum pump to remove gas. I hook it up with the cup like I was going to bleed brakes then when the line fills up I pinch the hose near the cup. I make sure that the cup is lower than the tank. Then I remov the cup from the line. If you do this right you will have gas flowing through the line still. You can then let the end of the hose go in a fuel can or jug. You could also use your mouth to suck the gas through the line, but I do not reccomend that.
Old Sep 1, 2012 | 02:36 PM
IslandBoy's Avatar
Quickest way,flip bike over.....jk.
If you don't have to remove for any other work go with a simple piece of tubing and a little mouth suction (I know,I know a little g@y)
Old Sep 1, 2012 | 03:55 PM
I just went to auto zone and got a siphon with the hand pump for 2 bucks lol It actually worked well thanks guys
murdocity
Sep 16, 2009 03:56 PM
Kuroshio
Jul 27, 2009 08:17 PM
BoakUtah
Mar 31, 2009 04:10 PM
BW
May 20, 2007 03:11 AM
infamous01
May 19, 2007 02:39 AM
