how do i adjust my clutch
RE: how do i adjust my clutch
you can adjust it in two places....first one is at the handlebar. by twising the adjustable bolt it will create less play in the wire (by unscrewing it) then tighten the nut once you have adjusted it. second you can adjust it at the other end of the cable. on my bike this is above the stator cover on the right side of the bike. this works in the same concept as the the handlebar adjustment, but is 2 nuts that yo will have to loosen to the same degree, adjust and retighten....let me see if i can find some pics.
Here ya go, this is obviously not the handlebar adjustment (thought i would say it just in case), adjust the nuts the in the direction of the arrow, that will tighten the cable up.
[IMG]local://upfiles/5310/289FA30E46EC47BF8C3F0AF2223B4134.gif[/IMG]
These are the nuts.
[IMG]local://upfiles/5310/A970C15BF2814C6F8FA8E0C2A5A66B79.gif[/IMG]
and....the clutch specs
[IMG]local://upfiles/5310/0B4494F9703A48DD9DE4B61BB0D2C8B5.gif[/IMG]
These are the nuts.
i get kinda what your saying. I want to adjust from the handlebars. Ive loosened the washer looking nut now do i want to turn the nuton the cable in the direction of tighting it or is there somthing i missing because it doesn't seem to take the slack outta my lever any. 06 f4i
