Higher Revs From N to 1 or 2.
Old May 9, 2012 | 06:11 PM
estate4life's Avatar
February 2012 ROTM
1.6 - 1.8 that's high idle bro....why is it adjusted so high in the first place....
Try adjusting back down to normal
Idling...I am not sure about your model & year (EFI) bit idle should be around 0.8 -1.2 at most....set you idle correct first then see how bike react....nothing relates with oil.... It's your fuel injection, fuel feed related...
Old May 9, 2012 | 08:21 PM
justasquid's Avatar
I agree with estate4life, your idle is set way too high. If you don't know, you can adjust your idle by the idle adjuster screw located on the left hand side of your bike. Turn the **** until your idle is down around 1200 or so. Do this when its fully warmed up though.
Its not good to overfill your oil, but it probably didn't hurt anything. Most cases you will loose power due to the crank actually being in oil and getting dragged down. The other possible outcome is purging the excess oil through the crankcase vent. You should be fine.
Is it possible you moved the idle adjuster while changing your oil? Did a friend help you with the oil change and perhaps mess with it not knowing what it was?
messenJAH
Mar 1, 2012 08:41 PM
dalves11
Sep 22, 2010 04:47 PM
19meza85
May 31, 2010 11:52 AM
Drekk
Jan 11, 2010 01:09 PM
TxRida
Aug 14, 2008 04:14 PM
