help passing emissions!
Hi all,
I'm new to this whole forum thing so I don't know if this is the right place to put this or not, but I need help. I have an 02 cbr600f4i that doesn't want to pass emissions. It only has 16k miles on it. It has a pc3 set as lean as possible and an Akrapovic full system exhaust on it. After the first time it failed I replaced the spark plugs on it. It failed again so I ran injector cleaner through it and it still won't pass. I was running 91 octane fuel through it the first time I emissioned it and am now running VP110 in it. Please any help would be greatly appreciated.
We don't have emission testing here, so I'm just going to throw out some ideas that may or may not work. You want to run the octane your bike was intended for. Higher octane has more resistance to detonation, so its actually harder to ignite and will burn cooler and slower. What this may mean is even though you are running the pc as lean as possible, it may still be leaving unburned fuel out the exhaust.
Also, make sure you have a full tank of fresh gas. you don't want any fuel system cleaner in the gas if your trying to pass emissions.
Also, make sure your bike is fully warmed up before the test. If its cold, the enrichener circuit will be active and it will be running rich.
Like I said though, I've never had to go through emission testing, so take it for what its worth.
wow, I just went on the longest internet tangent I've ever had. Saw this post 5 hours ago and than it started with fuel octane rating to how to make my bike run with higher octane gas better than power commanders to quick shifters (actually found out that they used to make them for bikes that cant have a PC) than to getting pulled over by a cop than cop beating up another cop than carpet cleaning back to here. . .
All I found for emissions was already stated by justasquid.
Everything here is from my car experience (I'm new to motorcycles!) so you may want to try and research it a bit before you take my word for it.
The sensor SHOULD be good for 60,000 miles (or so) I'm not sure of the mileage on your bike. However things like improper a/f mixture, or leaded gas can shorten that lifespan considerably.
The sensor should be either a 3 wire, or a 1 wire. If it's a 3 wire, 2 of those wires will be for a heater. These should have 12V when the bike is running. (Possibly with it simply "on" but I'm not sure. A wiring diagram will help you with both of the above.)
The remaining (or only) wire is the "signal" from the 02 sensor. This should "cycle between 0v and 1v again, with the bike running. The ECU uses this to adjust the A/F ratio under idle/light load conditions, so it will need to remain connected when you measure this.
If it doesn't cycle it could be that the sensor is bad, or it could also be that your a/f ratio is so far off the ecu can't compensate enough for it to get within the sensor's range.
Not sure if that is much help to you, but it's something to start with I guess.
