help with front sprocket install
Old Jun 28, 2006 | 09:55 PM
1stgrbandit's Avatar
Default help with front sprocket install
im about to change my front sprocket. im asuming i need to loosen the nuts on either side of the swingarm and scoot the wheel up and then punch out the 2 rivets on my chain.i guess that is the master link? then take the front sprocket off and throw the new one on. do i need to grease it up when i put the new one on? i appreciate any help i can get, thanks
Old Jun 28, 2006 | 11:16 PM
wolvrinewd's Avatar
Default RE: help with front sprocket install
Hopefully this will help. Good Luck
https://cbrforum.com/m_17497/tm.htm
Old Jun 29, 2006 | 09:54 AM
seldon929rr's Avatar
I am regearing the front of my 929 also. I did not have to remove the whole chain. I just took off the cover, scooted the rear wheel forward and removed,switched and reinstalled the front sprocket, slid the chain back over and it's good to go.
jamefs912
Jul 30, 2009 11:12 PM
cjbettis
Nov 6, 2005 12:07 PM
