front sprocket install
Old Jul 30, 2009 | 12:39 PM
jamefs912's Avatar
Default front sprocket install
Hey I'm about to switch out the front sprocket with a 14 tooth bit but my question is what size is the drive shaft nut. What tools are needed to make this install pretty easy, such as what size socket?? Thanks
Old Jul 30, 2009 | 03:12 PM
Sand.Man's Avatar
I can't remember the nut size, probably a 17mm, but you will want an impact wrench.
Old Jul 30, 2009 | 04:19 PM
jamefs912's Avatar
Ha well I got it off but apparently the guy I bought it from already had a 14 tooth sprocket on it. Looks like a 520 chain. Anyone wanna buy a 14 tooth front sprocket for a 530 chain lol
Old Jul 30, 2009 | 11:12 PM
Polonius's Avatar
easy on those sprocket cover bolts! Don't overtighten. I hope you have a torque-wrench. The cover bolts are 8mm. I think the sprocket bolt was 15mm? The torque spec is 55N.m / 5.5 kg.m / 40 ft-lb.
I didn't need an impact wrench to get my old one off.
Also, always change your sprockets and chain together. Old sprockets will slaughter new chains, and old chains will slaughter new sprockets. Complete waste of money. Unless you're one of those select few who watch their chains and sprockets EXTREMELY meticulously and know for 100% certain that the part isn't worn too much.
1stgrbandit
Jun 29, 2006 09:54 AM
cjbettis
Nov 6, 2005 12:07 PM
