HELP! does anyone have an answer!!!
Old May 15, 2007 | 08:03 PM
prerunnersd's Avatar
Default HELP! does anyone have an answer!!!
ive read a bunch of threads about fuel pumps not priming/ not working on f4i's. i have an '02 and im having the same problem withcranking and no fuel and the pump doesnt buzz when the key gets turned on.has anyone fixed the problem? everything ive read just chases it and i havent seen anything that works yet. any help is really appreciated, thanks
Old May 15, 2007 | 08:08 PM
Tahoe SC's Avatar
Default RE: HELP! does anyone have an answer!!!
what are you talking about? most have had their fuel pumps prime and have nailed it down to the bank angle sensor.
did you follow the steps that was done in those threads?
Old May 15, 2007 | 08:35 PM
these are what ive read so far..
https://cbrforum.com/m_295041/tm.htm
https://cbrforum.com/m_259937/tm.htm
https://cbrforum.com/m_293210/tm.htm
https://cbrforum.com/m_293409/tm.htm
https://cbrforum.com/m_213699/tm.htm
i guess what im trying to say is nothing has worked for me yet and im still lookin for help.do ineed to replace the BAS or bypass it or what?thanks
Old May 15, 2007 | 08:56 PM
Tahoe SC's Avatar
please list what you have done so far...and we can go from there!
Old May 15, 2007 | 10:16 PM
well today i was looking around and realized i am missing a headlight relay... would that be a cause. all the fuses are good and im checking the sensors(sidestand, clutch, neutral) and they are working correctly. the BAS is mounted correctly. i started to look through the harness and check for bad wires/shorts etc. im new to bikes so i just dont really know what to look for. thanks
jrossi90
Jun 22, 2009 10:45 PM
tareemup
May 17, 2009 10:27 PM
nathan672
Feb 24, 2009 06:28 PM
lapster78
Apr 12, 2007 01:49 AM
