NEED ANSWER on rim!!
Old May 13, 2009 | 11:49 PM
tareemup's Avatar
Default NEED ANSWER on rim!!
I know its probably been covered before but i need a quick accurate answer. Ive been searching a little and get 50/50s a lot but heard a VFR front rim will fit my F3??? TRUE?? Rotor also? Let me know asap thanks
Old May 15, 2009 | 10:45 PM
cgmiller83's Avatar
95-98 VFR the rim will look the same as the CBR F3 wheel and is the same. To give you a better idea. The front wheel I have is off a 95 VFR750 with rotors off a 97 F3. All the bearings, seals, rotors, and spacers are the same. Good luck finding a VFR rim. I lucked out finding mine and that was before the word got out on here.
Old May 17, 2009 | 10:27 PM
tareemup's Avatar
ok so will thr rotor from a stock VFR rim still fit?or can i just take it off my 98 stock rim and put it on the VFR rim??
jrossi90
Jun 22, 2009 10:45 PM
nathan672
Feb 24, 2009 06:28 PM
prerunnersd
May 15, 2007 10:16 PM
lapster78
Apr 12, 2007 01:49 AM
