Who can answer this???
Old Mar 20, 2007 | 11:14 PM
lapster78's Avatar
Default Who can answer this???
Ok .. my 1998 cbr900had a problem .. which i never knew the source .. every time i would hit 260kms (kilometers per hour) my bike would come to a complete stop it would stalland had to put it on neutral restartit while still on the highway ..can someone tell me why this was happening?? ( i say was cuz i sold it) got a 954 instead
Old Mar 27, 2007 | 01:17 AM
tank_900rr's Avatar
Default RE: Who can answer this???
Well just like cars, bikes were governed to certain velocities. What happens is that once you've achieveda programedvelocity, either the engine is at risk of damage or the bike has simply reached it's "governer" and will either stall(turn off) or bog down(deceleratesuddenly). The reason why mostvehiclesand motorcycleshavebeengoverned now in days is simply to not be able to outrun police...there are many reasons why, such as engine damage, wheels desintegrating and lack of control, but mainly cause cops don't want you to get away. OH, and before I go....FYI, there are ways to override "governers", each app. is different though.
Old Apr 1, 2007 | 02:16 AM
lapster78's Avatar
makes sense .. thanks
Old Apr 1, 2007 | 06:35 PM
nothwoodscbr's Avatar
I have a 99 900RR, and I've never had it shut down like that. As far as I know, there is no governor on it. I believe 260km is about 160mph, which it should go well over that at least on the speedometer.
Old Apr 9, 2007 | 07:33 PM
rideordie!'s Avatar
new bikesare speed limited to 186mph, for $30 you can buy a limiter tricker. the limiter works like this: the bike shuts down whenit reaches a certain rpm in 6th gear. the tricker makes the bike think it is still in 5th gear, therefore bypassing the limiter.
Old Apr 10, 2007 | 06:03 PM
900rrjunkie's Avatar
You need a fuel pump all or i should say most cbr need help above 150-160 to keep the fuel flowing to the carbs, it all has to do with gravity most cbr's are gravity feed so on the top-end they fall on there face put a fuel pump in see what happens.. And i dont think any 900 ever had a governer on it.
Old Apr 11, 2007 | 01:39 AM
rideordie!'s Avatar
sorry forgot yours is not fuel injected. my bad.
Old Apr 11, 2007 | 04:02 AM
johnnyh's Avatar
Some new bikes like the hyabusa have a gps tracking system, but they do it for warrantee purposes. If the bike hits 186 it informs the dealer and the driver owner receives a call an hour later telling him his warrantee is void. I know it happened to my freind on a cruise we made. On an other note the 900 does have a fuel pump, at list mine does. Mabe the fuel pump is'nt working properly, it does sound like a fuel problem. Johnny
Old Apr 12, 2007 | 01:49 AM
rideordie!'s Avatar
i recently put a 98 engine in a 95 cbr. everytime i got up in a wheelie it would cut out. i removed the fuel pump and put a direct (gravity fed) line in, cured the problem. don't know if yours has afuel pump, but if it does, get rid of it.
jrossi90
Jun 22, 2009 10:45 PM
tareemup
May 17, 2009 10:27 PM
nathan672
Feb 24, 2009 06:28 PM
prerunnersd
May 15, 2007 10:16 PM
