Does anyone know the answer?????
Old Jun 21, 2009 | 08:30 PM
jrossi90's Avatar
Default Does anyone know the answer?????
Hello Everyone,
This is my first post and I am in need of some SERIOUS help!!!
I have a 02 F4i with 70,000 km’s and it seems to have an extremely odd problem that no one can figure out, here are the symptoms:
While driving in any gear, when I push the engine anywhere past 9K it starts to stutter, loose power, get shaky and just sound terrible. 2 weeks ago I brought my bike to the SPECIALISTS (Honda Motorcycle) and they seem to be clueless as to what the problem is.
Here is what they have tried so far with no luck:
- First they told me that 2 of the ignition coils were dead and “arching” and so they replaced those and still the problem persisted.
- They told me a wiring harness was corroded and needed to be replace but still the problem persisted.
- They tried a brand new CDI box but still no luck.
- They did valve adjustments + timing but still no luck.
- They checked compression and fuel pressure and everything is fine there.
They have one last thing in mind and that is that the camshaft position sensor which I believe is supposed to be in charge of timing (I forget the exact name) needs to be replaced because it was knocked, also there is a similar sensor on the clutch that needs to be replaced, however they told me that if that doesn’t fix the problem they have exhausted all possibilities.
Has ANYONE seen anything like this and can anyone please help? I would be forever grateful!!!
Old Jun 21, 2009 | 11:25 PM
bwayers's Avatar
i'd have them test your pulse generator
Old Jun 22, 2009 | 02:03 PM
jrossi90's Avatar
The pulse generator is what Honda is looking at now, so it seems as though you are on the same track as they are. If that doesn't work does anyone else have any other suggestions?
Old Jun 22, 2009 | 02:52 PM
orags's Avatar
I get worried when the experts start to **** around with everything hoping for a fix. Almost a trial and error approach. Good luck on your experiments and lets know how it goes.
Old Jun 22, 2009 | 03:24 PM
tupperwareracing's Avatar
when in neutral does it run all the way to redline with no problems? if it does then it is the STATOR.... good luck
Old Jun 22, 2009 | 08:27 PM
jrossi90's Avatar
I don't exactly remember if it redlines in neutral, I have not been on it in a couple weeks, what exactly is the "stator"? Ill pose it to Honda.
Thx
Old Jun 22, 2009 | 08:29 PM
RojerLockless's Avatar
did tehy try just tightening the battery down even tighter? sounds to me like that's all it is.
Old Jun 22, 2009 | 09:54 PM
bwayers's Avatar
i'm assuming your bike functioned normally at lower revs?
also, did they replace your spark plugs or atleast clean them up?
Old Jun 22, 2009 | 10:45 PM
jrossi90's Avatar
The bike has amazing power below 9.5k, it idles amazing, it starts amazing, no FI lights, just above 10K it starts to act funny.
Brand new Batt 1 month ago nice and tight.
tareemup
May 17, 2009 10:27 PM
nathan672
Feb 24, 2009 06:28 PM
prerunnersd
May 15, 2007 10:16 PM
lapster78
Apr 12, 2007 01:49 AM
