Handle bar vibration...
Old Dec 29, 2005 | 07:45 AM
Muz's Avatar
Muz
Default Handle bar vibration...
I dropped my bike while stopped a couple of days ago and have replaced the bar end weights. It now feels like there is more vibration from in the handle bars in general and when I'm going about 80-90kms if I let go of the bars they actually start to shake. Can anyone tell me if this is from the new bar weights or if I could of damaged the front suspension.
Cheers people
Old Dec 29, 2005 | 05:49 PM
shraz's Avatar
Default RE: Handle bar vibration...
when you put your front tire straight does the handlebar match the position or is it off? look at your forks when you sit on the bike looking down for any curve or something not straight.
When you brake does it vibrate too? that could be the rotor
Old Dec 29, 2005 | 06:26 PM
doncollins's Avatar
Retired Administrator
I don't see how the bar weights would cause this... you could always take them off and see if it stops. How bad was the drop? Did the front hit anything or did you just lay it down on its side? Is the lead weight missing from the front wheel... the one used to balance it?
Old Dec 29, 2005 | 06:38 PM
shraz's Avatar
what does the weights really do? I only have 2 in the front in the middle (clipon) and none in the rear
Old Dec 29, 2005 | 06:40 PM
NINE2NINE's Avatar
Retired Mod
ORIGINAL: Muz
Cheers people
if the handlebars are physically moving/shaking then i really doubt it from the bar weights. i agree with don and check the rim for weights and any other previously unseen damage. ive went through 4 different sets of bar ends trying to cut down on vibration and they all seemed to be about the same.
Old Dec 29, 2005 | 06:52 PM
doncollins's Avatar
ORIGINAL: shraz
The weights on the rim are to balance it. When they manufacture wheels... they're not perfect. So you have them balanced by using a machine to spin the wheel and take reading where it's off balanced. Then you add weights to stop vibrations that you would feel at high speeds.
The bar end weights are also there to reduce vibration you'd feel in the clip-ons.
Old Dec 29, 2005 | 07:22 PM
Anubis's Avatar
Just to add.....
Whhels are normally minimally off balance the weights are more for the tyre. The bar end weights can effect vibration, but it depends on what you mean by vibration? a little or a lot? I`d check all the points mentions by Don but using different bar ends other than stock will makle a difference in vibration more so on the hands.
Old Dec 30, 2005 | 02:42 AM
shraz's Avatar
good 2 know
Old Dec 30, 2005 | 05:50 AM
Muz's Avatar
Muz
Cheers for the feedback, I think i'll take it in and get them to check if its balanced properly
Kevwa451
May 18, 2015 07:14 PM
joel45acp
Jul 28, 2009 11:13 PM
jrocken
Aug 7, 2006 10:25 PM
LoNeProBE
Feb 24, 2006 06:00 AM
Red Baron
Aug 8, 2005 06:07 PM
