Fried ECU?
Fried ECU?
Yesterday changed the headlights bulbs (NOTE: i get the 12v signal from some wire that send signal when switch is in ON position), i start the bike and around a minute later it shut down.
Lights, stop and directionals are ok but fuel pump doesnīt activate and starter switch is dead also. Fuses from fuse box are ok, checked starter selenoid fuse and is ok too, changed main fuse but nothing happens, check voltage from battery and some wiring and is 12v.
What else i can check for problems???
Have you tried to unwire the headlights to see if you can reverse the situation?
Will the bike push start?
the fuel pump is probably not activating because it has pressure. I believe those models only activate the pump when the pressure drops. So I don't know if the fuel pump is related or not.
The first thing I would check though is the kickstand switch. Then the killswitch, then maybe the neutral safety switch.
If the bike was running fine, then its more than likely something simple. Its just a matter of finding it.
Tomorrow im goint to check some wiring to see if i hit the problem
Ok... today i follow the route from that wire where i take the 12V signal for my headlamps, and that wire goes also to the on-off switch, IGNITION COIL and CDI (ecu).
Im pretty shure i fried the CDI
There is any way i can check the CDI to see if is fried????
Ok... i am still checking the wiring but theres no 12V signal from the battery to the CDI (ecu) or from the battery to the different components like starter switch or on/off switch.
It was probabbly a bad starter relay, but i donīt know how to check it
