Fried ecu / cdi?....probably
Old Apr 3, 2008 | 02:20 PM
kmboll's Avatar
Default Fried ecu / cdi?....probably
I was having trouble push starting my bike after the winter so I decided to just have someone jump it with their car (apparently I should have checked here first). When I connected the jumpers, the bike lights and everything came on fine. But, as soon as I hit the starter button it sounded like I blew a fuze and everything instantly died. No lights, no nothing. Even though the bike was still connected to the car, I couldn't get ANY power. I figured I just blew some fuze, but they are all fine. Then I checked my connections and everything seems to be ok and nothing is loose or burned out. So......it seems like I probably fried my ecu. Any other thoughts before I go and buy another one?
Old Apr 3, 2008 | 02:31 PM
Nauree's Avatar
Default RE: Fried ecu / cdi?....probably
Was the car running when you jumped off of it? If it was you just blew your bike up. You can jump it from a car but it has to be off.
Old Apr 3, 2008 | 02:47 PM
kmboll's Avatar
yea, running (feeling stupid)
blew my bike up meaning.....ecu? or something else?
Old Apr 3, 2008 | 06:10 PM
fishfryer527's Avatar
Depending on your bikethere may be two places for fuses, maybe you only checked one of them. Also I have had fuses that looked good, but were really bad. I hope it is isn't the ECU, good luck.
Old Apr 3, 2008 | 06:16 PM
joshua9853's Avatar
did u check the fuse under the seat.
Old Apr 3, 2008 | 06:35 PM
Also...before you go and get a new ECU try a different battery.
Old Apr 4, 2008 | 08:08 AM
MikeInCtown's Avatar
Jumping from a car shouldn't have fried anything. 14v DCfrom a car is the same as 14v DCfrom a bike. It doesn't matter what the source of the voltage is as long as it is correct. The battery you use could be 1 million CCA and it wouldn't matter. The bike will only use the amperage it needs. (did you actually connect the cables correctly?)
I agree with the others who said check for fuses.
Grkan13
Jul 7, 2012 07:50 PM
hard2obtain
Mar 9, 2011 10:53 PM
wrx_punk
Apr 15, 2010 01:19 PM
handiddy
Jun 24, 2008 07:00 PM
QuikSilver
Oct 18, 2004 04:13 PM
