Fried Cables
Old Jul 7, 2012 | 08:09 AM
Grkan13's Avatar
Default Fried Cables
Hello,
My bike stopped when I was riding, then i saw that my battery was dead, i tried to push start, it started for 10 second, then it didnt again.
Then I started take out plastics and that's what i've found.
Should i just change rectifier or is there any way to test my rectifier is good or bad?
Thank you.
Old Jul 7, 2012 | 10:11 AM
74demon's Avatar
Fix the wiring. Just bypass the connector if you dont want to replace it. Test your charging system. That will tell you if the r/r is any good.
Old Jul 7, 2012 | 05:21 PM
sjona2011's Avatar
if its getting hot enough to melt the connectors, then the r/r is probably bad.
i recently replaced mine with one from a gixxer. 2002 or 2003 i believe.
its significantly larger and a bit of a paint to mount, but works like a charm.
Old Jul 7, 2012 | 07:50 PM
adidas_007's Avatar
x2 I also went with the gsxr R/r, it is bigger but it's the heatsinks that are whats bigger.
LINK: https://cbrforum.com/forum/f2-tech-9...-solved-27739/
hard2obtain
Mar 9, 2011 10:53 PM
wrx_punk
Apr 15, 2010 01:19 PM
csjray
Oct 13, 2008 09:37 PM
handiddy
Jun 24, 2008 07:00 PM
kmboll
Apr 4, 2008 08:08 AM
