Fixing up a sitting bike
Is there any way to find cheaper replacement parts for all the gaskets, o-rings, etc?
I've been using Bike Bandit previously for the OEM stuff, but they want $23 a pop for the float bowl gasket. I know this is supply and demand stuff (no one is buying for this model anymore) but it can't possibly cost that much to make a little piece of rubber...
Also, I'm noticing a lot of corrosion/rust on parts where it probably shouldn't be. Most notably my rear axel. I'm sure it would still roll just fine, but at what point should I be worried about that kind of wear?
I'll post some pics later today.
I seen someone a while back used big O rings for replacement float bowl gaskets, but dont remember which CBR forum it was. But I would think you could kind of lay a piece of string in place of the gasket, then cut to length, then butt the two ends together in the form of a circle, then get big round rubber circle gaskets the same size as your string circle. And use as new gaskets. Might take a little heat to form to shape needed for float bowls but it should be cheap enough to try. Even if it didnt work at least it was a cheap try.
Wherever you get them, you have to insure they are rated for gasoline else they will be eaten away after a while
oacuna
Jan 22, 2007 05:51 PM
