Engine rebuild help. is this good or bad?
Old Aug 2, 2010 | 08:53 AM
knifemaker87's Avatar
July 2011 ROTM
Default Engine rebuild help. is this good or bad?
okay!
I am rebuilding my cbr 600 f2 engine that has been leaking oil and water mixed; and out of some weird places... like oil out of the water pump, i dont know how recently the bike was run. i have a complete upper and lower gasket and seal set, and want to do this right, but dont know what looks good or bad
Now, i will say this up front, i do not know what wear looks like, so if you see something that should be fixed or replaced PLEASE shout it out. i need you engine gurus to help me out here. thanks!
Here we go:
Valve cover removed, i didnt figure you needed a picture of the valve cover on....
Now, loosen the bold in reverse numerical order to allow the covers to de-compress evenly (dont worry... they are numbered)
i guess i should post pics of the cams to check for abnormal wear or damage...
valve followers numbered for removal:
valve followers and shims removed
head removed: look at the water where the head gasket was...
Blown head gasket...now, the $5 million question is... is the head warped?
Clutch cover removed... and why is there coolant in here?
it would appear that someone has been here before me... (and the put on the washer that says "outside" on one side... the wrong way around...) FAIL! new nut ordered... aslo the cover was put on without a gasket.. just some RTV
is this stock?! i know one of the POs used this as a race bike...
removing the oil pan... EW! at least it isnt milky right? could all this have leaked through the head gasket? this seems like alot of "leakage"
oil cooler...
oil cooler GONE!
removing the gear shift mechanism
used a wire brush on the piston heads... cleaned up real nice!
stator cover removed:
Pile of parts on the bench...
I am kinda stuck cause i need a "honda service too" to remove the magneto as well as a funky torx, so i have to find something that works, or find a tool. any info on that? after that comes off i will be able to split the cases and double check that there isnt a hole the coolant is leaking out of, then everything will get cleaned and re-assembled with new gaskets and seals... i am gonna do a valve job for sure, but not till i get everything else back on.
anything else i should do while i have it open?
thanks for looking!
~Chris
Old Aug 2, 2010 | 05:15 PM
pacemaker's Avatar
Maybe compound (grind) the valves & get rid of the carbon build up.
I guess with a blown gasket that you're going to get coolant just about every where oil can get. Have the head checked out, as you don't want the gasket to blow again after all that work.
Try striking up a deal with the local Honda guy for those "Special" tools, you may have to leave a deposit & a fee, but it may save you some money.
The way you have set up you're bench & posted the photos, shows that you're methodical & I suspect, well up to the task. In a way I'm almost envious of what you are about to do. Good Luck & keeps us posted on the progress.
jscrogg98
Aug 21, 2013 04:42 AM
catworst
Aug 14, 2013 04:30 PM
sandrailman
Jun 3, 2013 05:18 PM
knifemaker87
F2 Tech
Sep 17, 2010 09:21 AM
zer0gh0st
Apr 20, 2006 01:18 AM
