do it yourself painting ?
Old Aug 4, 2010 | 03:03 PM
allnightsurfsesion's Avatar
Default do it yourself painting ?
i just bought a cbr600rr that was dropped at a slow speed i wanted to re paint a fender. i was wondering if anyone knew what paint to use and how to go about painting it. please help thanks
Old Aug 4, 2010 | 04:49 PM
bammerman's Avatar
I used Rhino Liner
but a good ppg paint from autozone, etc... would work. just sand / primer / wetsand / paint / wet sand / and clear coat and you will be good.
Old Aug 4, 2010 | 10:46 PM
justasquid's Avatar
If your looking to factory match it, www.colorrite.com has the correct colors they send to you either in arosol cans, paint pens, or half pints. If you have the ability, buy the half pint and clear and it will last a long time. However, a half pint is only enough to do a little more than a fender, so it doesnt go very far. And its pricey.
You could go to your local autobody store and have them colormatch it for you.
Or, which is usually cheaper and easier for small items, check on ebay and buy a good used fender in your color. It would probably be cheaper than trying to repaint the one you have. You can usually pick up a good fender on ebay for 20-30 bucks.
Old Aug 4, 2010 | 11:35 PM
Kuroshio's Avatar
Ok so what are the winning lottery #s for Friday's Powerball???
I was just thinking today of trying to find a touch up pen to eliminate that single scratch on my F4i. But figured matching the color would be a PITA. Colorrite has the "Cany Tahitian Blue" and the base Bookmarked for after I get a FPR
Old Aug 5, 2010 | 09:26 AM
AmericanOne's Avatar
I've used the spray paint cans from colorrite.com for a small damaged section on my car door and recently on my f3 from where the previous owner had dropped it. If you take the time to prep and sand it properly and use the spray primer, color and clear it will match your existing colors great and is hard to tell it was done from a can. The only real downside is that it won't last as long as using a spray gun and better clear but the car part I painted with the spray cans has lasted over a year without damage/peeling/fading. Heck it even made it through this past winter.
If you have painted using a gun before then go for it. It def is the better option. But if you haven't I'd recommend the spray cans. =P good luck!
Old Aug 7, 2010 | 09:50 AM
DonEverett's Avatar
I've also used the colorite products with great results. Just take your time and it works great!
Wisconsin
May 17, 2012 11:07 AM
blubo2256
Mar 8, 2012 10:59 AM
sssmasss
May 13, 2009 02:39 PM
Noah0708
Nov 15, 2008 10:31 AM
Jump1979man
Mar 7, 2008 12:29 PM
