Connecting battery to starter directly.
Old May 22, 2011 | 03:47 PM
EL Thorsby's Avatar
Default Connecting battery to starter directly.
How do I connect the starter motor terminal to the battery terminal to try to figure out if its my starter motor thats faulty or relay, or the cable? It would very appreciative if anyone as any advice for me.
Old May 22, 2011 | 08:18 PM
raiden's Avatar
is it still cranking?
post a video..
Old May 22, 2011 | 09:15 PM
adrenalnjunky's Avatar
jumper cables would be my method.
Old May 22, 2011 | 09:29 PM
dannoxyz's Avatar
Clamp negative-cable to case of starter. Pull back rubber cover over positive-terminal of starter (it has the bolted-on cable from the starter-relay). Then tap the positive-cable to the positive-terminal of starter. Make sure you're in neutral.
Another way to test relay is to use voltmeter. Put negative to case of starter. Put positive-probe to positive terminal. When you push starter-button, you should see battery-voltage at the positive-terminal on the starter. Can also hear the starter-relay click.
Old May 22, 2011 | 09:56 PM
EL Thorsby's Avatar
The only sound coming from the starting system is the click of the relay. Earlier I disconnected the relay to the starter motor, and connected the starter motor to the positive side of battery. And tried to start it to see if the starter would try to start over, but it wouldn't.
[QUOTE=dannoxyz;1057366]Clamp negative-cable to case of starter. Pull back rubber cover over positive-terminal of starter (it has the bolted-on cable from the starter-relay). Then tap the positive-cable to the positive-terminal of starter. Make sure you're in neutral.
Could you please explain more about the clamp negative-cable part. I don't really understand how that would work, with it not connecting to the battery?
Old May 22, 2011 | 10:40 PM
If you connect a cable from the positive battery terminal directly to the positive lug on the starter motor, then the starter motor should turn over immediately and keep running until the cable is disconnected. You don't have to hit the starter button, you're bypassing all of the bike's starting system.
Old May 23, 2011 | 02:47 PM
dannoxyz's Avatar
The negative side of the circuit should already be grounded to the frame anyway. But I like to run a negative-cable just in case. So I clamp it to the body of the starter or to the bolt that holds it to the engine. Then tap the positive-terminal with the other cable.
theadamie
Mar 8, 2014 07:08 PM
VALKYIE
Jun 8, 2013 03:23 AM
Kurtz
Oct 5, 2009 07:15 AM
onewheelbandit
May 9, 2006 02:35 AM
icebox
Jul 26, 2005 11:47 AM
