Connecting battery to starter directly.
Another way to test relay is to use voltmeter. Put negative to case of starter. Put positive-probe to positive terminal. When you push starter-button, you should see battery-voltage at the positive-terminal on the starter. Can also hear the starter-relay click.
The only sound coming from the starting system is the click of the relay. Earlier I disconnected the relay to the starter motor, and connected the starter motor to the positive side of battery. And tried to start it to see if the starter would try to start over, but it wouldn't.
[QUOTE=dannoxyz;1057366]Clamp negative-cable to case of starter. Pull back rubber cover over positive-terminal of starter (it has the bolted-on cable from the starter-relay). Then tap the positive-cable to the positive-terminal of starter. Make sure you're in neutral.
Could you please explain more about the clamp negative-cable part. I don't really understand how that would work, with it not connecting to the battery?
If you connect a cable from the positive battery terminal directly to the positive lug on the starter motor, then the starter motor should turn over immediately and keep running until the cable is disconnected. You don't have to hit the starter button, you're bypassing all of the bike's starting system.
theadamie
03-08-2014 07:08 PM
