charging problem
Old Jul 8, 2007 | 01:05 PM
transman50's Avatar
Default charging problem
im working on a gold wing 1984 1200 aspencade bike died on road charged it up it started i stated checking the system, i found rectifier bad i replaced it i charged battery but heres where im confused, on charger it had 12.5 volts it wouldnt get any higher i read it should be 12.8 or higher at full charge, i put battery in started it up warmed it but volt meter on battery reved engine voltage was low it dropped instaed of raising up to 14-15 volts liked its supposed to my question is do i have a bad battery or do i gotta look further than the rectifier. thanks greg
Old Jul 9, 2007 | 10:15 AM
Tahoe SC's Avatar
Default RE: charging problem
yea you need to check to see if the alternator is giving the rectifier the right amount of juice.
gdjohny
Jan 10, 2014 12:09 PM
mjimenez1
Feb 6, 2010 09:28 AM
blaster
Nov 19, 2007 12:02 PM
jasonp
May 2, 2007 02:44 PM
