Changing Brake Pads on a 05 CBR 600RR
just like its done on the F4/i. You really dont even have to remove the calipers. Remove the two pin bolts that run thru the the caliper and pads. Use a screwdriver to pry the pads back (compressing the caliper). Slide the old pads out, slid the new pads in, put the bolts back in n tighten em. On the rear, use a screwdriver to force the pads back. Theres one bolt that needs to be loosened on the rear of the caliper, then it can rotate up n forward allowing the pads to be removed n replaced.
