Changing Brake Pads
Old Apr 10, 2008 | 12:08 PM
G3NESYS's Avatar
Default Changing Brake Pads
ok i dida search on brake pads and founda few posts, but none of them said anything about how to change them.
my front brakes do a little "lunging" when i brake, like slightly harder on one area so it bounces when i brake... i made a post about this before.
i went to the local bike shop here and they said it could just be the pads and that they would change them for $35
i would like to do it myself b/c i like workin on my own stuff, and brake pads seem pretty simple so i was just wondering how hard it is to do them. is it just as simple as loosening the old ones, slipping them out, and putting new ones in?
Old Apr 10, 2008 | 12:11 PM
krash's Avatar
Default RE: Changing Brake Pads
yup, that easy, and torque everthing back to where it should be.
the only possible hang up is if your pads are severly worn down, you will need to open the mastercylinder so that you can push the pistons back inside the
calipers a little so they will fit back over the disk.
Old Apr 10, 2008 | 03:14 PM
Stephens's Avatar
Its really easy to do, you have to have a C clamp to compress the pistons and then once on the bike you press the brake lever or press with your foot to "set the pad".
Old Apr 10, 2008 | 04:57 PM
Fort Collins's Avatar
ya it's just as simple as changing the pads on your car if you have ever done that. but not worries it's just a matter of how to take them off it goes back together the same way. lol
Old Apr 10, 2008 | 05:09 PM
PlayfulGod's Avatar
ORIGINAL: Fort Collins
actually its easier lol. I can change my fronts w/o removing the calipers. Takes roughly 20 - 30 minutes, maybe longer if you have never done anything like it b4.
Old Apr 10, 2008 | 06:22 PM
some guy #2's Avatar
I had never done anything like changing brake pads before and it was very simple. The hardest part was braking (horrible pun) them in, since I wasn't sure what exactly you weren't supposed to do.
Old Apr 10, 2008 | 07:50 PM
Pacs_Legend's Avatar
Does anyone ever resurface their bike rotors?
Old Apr 11, 2008 | 01:08 AM
axsys's Avatar
G3NESYS, do you have a manual for your bike? they have pretty good instuctions int here on how to change them
Old Apr 11, 2008 | 09:19 AM
sluijs01's Avatar
ORIGINAL: axsys
+1 on the manual
That's what I used the first time I changed mine. That, and just light searching on the internet, cause at a certain point, changing disc brake pads is all the same idea
Old Apr 11, 2008 | 12:29 PM
Jaybird180's Avatar
Clean & lube your pistons while you're at it. There's a write-up somewhere for that too.
jeffjones
Oct 27, 2010 12:38 PM
CYCDUP
Aug 20, 2009 06:13 AM
sstgonzo
Aug 17, 2007 01:09 AM
bluestanger66
May 12, 2007 04:17 PM
fading@verizon.net
Oct 17, 2006 07:39 PM
