chain help
Old Feb 16, 2011 | 03:16 PM
sunny's Avatar
Default chain help
hey guys i am lookin for some advise on what chain and sprockets i should go with i bought a used 96 f3 and after riding it last summer right before the snow started to fall my chain snapped and the guy i bought it from said he put diff spockets on it but i have no idea what they are is there any way to tell? what would be the best setup just for crusin around town and back and forth to work?
Old Feb 16, 2011 | 03:32 PM
Conrice's Avatar
general rule of thumb : if you're replacing a chain, you should replace both sprockets and chain at the same time. if you don't, your chain and sprockets will wear down twice as fast (due to the wear patterns of your chain and sprockets)
since you have an f3, get a 520 kit. you should be able to find a 520 chain kit that will come with a new chain and new sprockets on fleabay - or any reputable motorcycle shop online. as far as what to get, get a 520 (you don't need a 530 which is what is stock), and you can get a kit that comes with a -1 tooth countershaft sprocket which will give you a nice little boost in acceleration, but won't kill your gas mileage. that's what i had on my f3, i still got over 30 mpg, and the bike was nice and peppy.
and especially since you don't know what size your sprockets are (which is hard to tell by sprockets), since you snapped a chain (which means your sprockets are probably also worn, at least worn enough to the point to where they have their own wear pattern started), get a new kit.
Old Feb 16, 2011 | 04:25 PM
billetproof97's Avatar
525 or 530 IMO.
Old Feb 16, 2011 | 04:36 PM
gotcbr's Avatar
http://www.sprocketcenter.com/p/3149...2f3-91-96.html
Old Feb 17, 2011 | 03:08 PM
sunny's Avatar
thanks for the help just ordered my 520 kit today im gunna attemp to put it on myself never done one but with quite a bit of mechanical knolege i think i should be able to figure it out
Old Feb 17, 2011 | 03:21 PM
gotcbr's Avatar
Use Incognito's excellent HOW-TO here...
https://cbrforum.com/forum/how-mechanical-40/chain-sprocket-swap-97641/
davedude44
Jun 28, 2012 12:22 PM
TheHeggi
Aug 11, 2010 04:58 PM
Perranomous
Apr 19, 2009 03:04 AM
crookedeyemotocross
May 4, 2006 10:14 AM
