chain ?
Old Feb 6, 2006 | 07:27 PM
surf's Avatar
Default chain ?
I need a new chain, what brand are most of you running? and what about the 520 conv? how much can you expect from changing over to it. I'm thinking about getting the new X ring RK530XSO. anything good or bad about RK chains
Old Feb 6, 2006 | 08:13 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: chain ?
What do you want out of it -- just a new chain? Or did you want to play with the gearing a bit? I'm running the RK 520 on my 1000RR with no problems for 5K miles. I'm considering going back to my old 530 luggy chain and sprockets for gas mileage reasons for the rest of the winter. But if you're satisfied with how your bike accelerates and tops out then go back with stock sprockets and chain of your choice. I've had excellent experience with RK and D.I.D chains -- not so good with EK[:'(]
Old Feb 6, 2006 | 10:09 PM
surf's Avatar
Default RE: chain ?
I do a lot of freeway miles so I want something that will last but I've heard that the 520 frees up a little H.P. My bike is a "00"929rr with pwrprogrmr, Full erion pipe, has great top end now. What do you get with regearing , more bottom end?
Old Feb 6, 2006 | 10:21 PM
Default RE: chain ?
Exactly -- quicker acceleration at the expense of top end. If you do mostly freeway then it might be a bit buzzier also. If you're happy now then I wouldn't change anything. Putting a 520 on with the same gearing will free up a bit of power but nothing earth shattering.
Old Feb 7, 2006 | 04:48 AM
shraz's Avatar
Default RE: chain ?
change your spockets w/ it
make sure u get an X-ring chain
Old Feb 7, 2006 | 07:58 AM
Anubis's Avatar
Default RE: chain ?
D.I.D and R.K Always been the best in my experience last longer than anything else I`ve used.
I personally am not a convert to the 520 conversion thinking. I mean when i`m yankin the throttle to the stop I like to know theres a nice thick chain there no chance of stretch or break.
Just my op.
davedude44
Jun 28, 2012 12:22 PM
TheHeggi
Aug 11, 2010 04:58 PM
Perranomous
Apr 19, 2009 03:04 AM
crookedeyemotocross
May 4, 2006 10:14 AM
